security protocol show
Show application configuration options
The security protocol show
command displays the cluster-wide configuration of RSH and Telnet in the cluster in advanced privilege mode. RSH and Telnet are disabled by default. Use the security protocol modify command to change the RSH and Telnet configuration that the cluster supports.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-application <text>]
- application-
Displays the insecure applications in the cluster.
[-enabled {true|false}]
- enabled-
Displays whether the application is enabled or disabled in the cluster.
The following example shows the default security protocol configurations for a cluster:
cluster1::> security protocol show Application Enabled ------------ ------------- rsh false telnet false
The following example shows the security protocol configuration after RSH and Telnet have been enabled:
cluster1::> security protocol show Application Enabled ------------ ------------- rsh true telnet true
