system cluster-switch polling-interval modify
Modify the polling interval for monitoring cluster and management switch health
The system cluster-switch polling-interval modify
command modifies the interval in which the cluster switch health monitor polls cluster and management switches.
[-polling-interval <integer>]
- Polling Interval-
Specifies the interval in which the health monitor polls switches. The interval is in minutes. The default value is 5. The allowed range of values is 2 to 120.
cluster1::> system cluster-switch polling-interval modify -polling-interval 41
Modifies the polling interval of the switches.
