statistics show-periodic
PDF of this doc site
Creating your file...
Continuously display current performance data at regular interval
This command continuously displays specified performance data at a regular interval. The command output displays data in the following columns:
This command has been deprecated and may be removed from a future version of Data ONTAP. Use the "statistics show" command with the tabular format instead. |
cpu avg: Average processor utilization across all processors in the system.
cpu busy: Overall system utilization based on CPU utilization and subsystem utilization. Examples of subsystems include the storage subsystem and RAID subsystem.
total ops: Number of total operations per second.
nfs-ops: Number of NFS operations per second.
cifs-ops: Number of CIFS operations per second.
fcache ops: Number of 7M flexcache operations per second.
pkts recv: Number of packets received over physical ports per second.
pkts sent: Number of packets sent over physical ports per second.
total recv: Total network traffic received over physical ports per second (KBps).
total sent: Total network traffic sent over physical ports per second (KBps).
data busy: The percentage of time that data ports sent or received data.
data recv: Network traffic received on data ports (KBps).
data sent: Network traffic sent on data ports (KBps).
cluster busy: The percentage of time that cluster ports sent or received data.
cluster recv: Network traffic received on cluster ports (KBps).
cluster sent: Network traffic sent on cluster ports (KBps).
disk read: Data read from disk (KBps).
disk write: Data written to disk (KBps).
[-object <text>]
- Object (privilege: advanced)-
Selects the object for which you want to display performance data. The default object is "
cluster
". [-instance <text>]
- Instance (privilege: advanced)-
Selects the instance for which you want to display performance data. This parameter is required if you specify the
-object
parameter and enter any object other than "cluster
". Multiple values for this parameter are not supported.For example, if you want to display disk object statistics, you can use this parameter to specify the name of a specific disk whose statistics you want to view.
[-counter <text>]
- Counter (privilege: advanced)-
Selects the counters for which you want to display performance data. If you do not specify this parameter, the command displays statistics for all of the counters in the specified objects. To specify multiple counters, use "|" between each counter.
[-preset <text>]
- Preset (privilege: advanced)-
If this parameter is specified, the command displays statistics for the specified preset.
[-node {<nodename>|local}]
- Node (privilege: advanced)-
Selects the nodes for which you want to display performance data. The default node is "
cluster:summary
". [-vserver <vserver name>]
- Vserver (privilege: advanced)-
Selects the Vserver for which you want to display performance data. If you do not specify this parameter, the command displays statistics for all of the Vservers in the cluster.
[-interval <integer>]
- Interval in Seconds (privilege: advanced)-
Specifies, in seconds, the interval between statistics updates. The default setting is 1 second.
[-iterations <integer>]
- Number of Iterations (privilege: advanced)-
Specifies the number of iterations the command runs before terminating. The default setting is 0 (zero); this means that the command continues to run until you interrupt it by pressing Ctrl-C.
[-summary {true|false}]
- Print Summary (privilege: advanced)-
Specifies whether the command prints a final summary of statistics after the command has gone through all of its iterations. The default setting is
true
. [-filter <text>]
- Filter Data (privilege: advanced)-
Selects instances that match the specified filter criteria. For example, to display instances from node1, specify
-filter "node_name=node1"
The following example displays the "cluster" statistics for a node named node1. Because no number of iterations is specified, this command will continue to run until you interrupt it by pressing Ctrl-C.
cluster1::*> statistics show-periodic -node node1 cpu cpu cpu total fcache pkts pkts total total data data data cluster cluster cluster disk disk avg busy total ops nfs-ops cifs-ops ops recv sent recv sent busy recv sent busy recv sent read write ---- ---- ----- -------- -------- -------- -------- -------- -------- -------- -------- ---- -------- -------- ------- -------- -------- -------- -------- 6% 6% 26% 0 0 0 0 641 39 126KB 4.68KB 0% 7.33KB 0B 0% 111KB 4.68KB 0B 0B 5% 5% 21% 0 0 0 0 254 7 16.7KB 1.75KB 0% 5.60KB 0B 0% 5.48KB 1.75KB 0B 0B 6% 6% 24% 0 0 0 0 307 41 21.2KB 5.32KB 0% 6.13KB 0B 0% 8.99KB 5.32KB 0B 0B 4% 4% 17% 0 0 0 0 364 16 23.8KB 2.58KB 0% 8.88KB 0B 0% 6.05KB 2.58KB 0B 0B 10% 10% 42% 0 0 0 0 673 7 124KB 1.92KB 0% 9.82KB 0B 0% 104KB 1.92KB 0B 0B 7% 7% 28% 0 0 0 0 407 38 28.1KB 4.38KB 0% 8.79KB 0B 0% 10.5KB 4.38KB 106KB 528KB 4% 4% 19% 0 0 0 0 328 16 21.6KB 2.58KB 0% 7.27KB 0B 0% 7.02KB 2.58KB 0B 0B 5% 5% 22% 0 0 0 0 324 31 21.9KB 4.35KB 0% 6.99KB 0B 0% 7.95KB 4.35KB 0B 0B 5% 5% 21% 0 0 0 0 242 16 16.1KB 2.60KB 0% 5.10KB 0B 0% 5.89KB 2.60KB 0B 0B 4% 4% 17% 0 0 0 0 273 16 18.0KB 2.60KB 0% 5.91KB 0B 0% 6.20KB 2.60KB 0B 0B
The following example displays the "processor" statistics for an instance named processor1. This command will display only five iterations.
cluster1::*> statistics show-periodic -object processor -instance processor1 -iteration 5 instance processor sk name busy switches -------- --------- -------- processor1 8% 1722 processor1 6% 1234 processor1 5% 1680 processor1 4% 1336 processor1 7% 1801 [...]
The following example displays the processor statistics for an instance named processor1 and counters "processor_busy" and "sk_switches". This command will display only five iterations.
cluster1::*> statistics show-periodic -object processor -instance processor1 -iteration 5 -counter processor_busy|sk_switches processor sk busy switches --------- -------- 5% 1267 4% 1163 7% 1512 5% 1245 4% 1128 [...]
