lun import start
Start the import for the specified LUN
This command initiates the data import to a specified LUN.
You must use the lun import create command to create an import relationship between a LUN and a foreign disk before you can initiate the data import.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver that contains the LUN you want to import data to.
-path <path> - LUN Path
Specifies the path of the LUN that you want to import data to. Examples of correct LUN paths are /vol/vol1/lun1 and /vol/vol1/qtree1/lun1 .
cluster1::> lun import start -vserver vs1 -path /vol/vol2/lun2
Starts the data import to lun2 at the path /vol/vol2/lun2.
