The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network interface start-cluster-check
PDF of this doc site
Creating your file...
Your file is ready
Start the cluster check function
The network interface start-cluster-check
command initiates an accessibility check from every logical interface to every aggregate. Automatic checks run periodically, but this command manually initiates a check immediately.
This command produces no direct output. Any errors encountered during the check are reported in the event log. See the event log show command for more information.
This example shows an execution of this command, with all parameters and output.
cluster1::> network interface start-cluster-check
