metrocluster check node show
Show results of MetroCluster check for nodes
The metrocluster check node show command displays the results of node checks performed by the metrocluster check run command.
The command displays the results of the following node configuration checks:
  • node-reachable: This check verifies that the node is reachable.
  • metrocluster-ready: This check verifies that the node is ready for MetroCluster configuration.
  • local-ha-partner: This check verifies that the HA partner node is in the same cluster.
  • ha-mirroring-on: This check verifies that HA mirroring for the node is configured.
  • ha-mirroring-op-state: This check verifies that the HA mirroring operation is online.
  • symmetric-ha-relationship: This check verifies that the relationship between the node and its HA partner is symmetric.
  • remote-dr-partner: This check verifies that the DR partner node is in the remote cluster.
  • dr-mirroring-on: This check verifies that DR mirroring for the node is configured.
  • dr-mirroring-op-state: This check verifies that the DR mirroring operation is online.
  • symmetric-dr-relationship: This check verifies that the relationship between the node and its DR partner is symmetric.
  • remote-dr-auxiliary-partner: This check verifies that the DR auxiliary partner node is in the remote cluster.
  • symmetric-dr-auxiliary-relationship: This check verifies that the relationship between the node and its DR auxiliary partner is symmetric.
  • storage-failover-enabled: This check verifies that storage failover is enabled.
  • has-intercluster-lif: This check verifies that the node has an intercluster LIF.
  • node-object-limit: This check verifies that the node object limit option for the node is turned on.
  • automatic-uso: This check verifies that the automatic USO option for the node is enabled.
Additional information about the warnings (if any) and recovery steps can be viewed by running the command with the -instance parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node <Node name>] - Node Name
This is the name of the node for which the check was run. If this parameter is specified, only rows with this node will be displayed.
[-check <MetroCluster Node Check>] - Type of Check
This is the type of the check performed. If this parameter is specified, only rows with this check will be displayed.
[-cluster <Cluster name>] - Cluster Name
This is the name of the cluster the node belongs to. If this parameter is specified, only rows with this cluster will be displayed.
[-result {ok|warning|not-run|not-applicable}] - Result of the Check
This is the result of the check. If this parameter is specified, only rows with this result will be displayed.
[-additional-info <text>] - Additional Information/Recovery Steps
This is additional information about the check. This field has more information and recovery steps for the warning. If this parameter is specified, only rows with this additional info will be displayed.
The following example shows the execution of the command in a MetroCluster configuration with two nodes per cluster:
clusA::> metrocluster check node show
Last Checked On: 9/12/2016 13:47:00
Node                  Check                                Result
clusA-01
                      node-reachable                       ok
                      metrocluster-ready                   ok
                      local-ha-partner                     ok
                      ha-mirroring-on                      warning
                      ha-mirroring-op-state                ok
                      symmetric-ha-relationship            warning
                      remote-dr-partner                    ok
                      dr-mirroring-on                      ok
                      dr-mirroring-op-state                ok
                      symmetric-dr-relationship            ok
                      remote-dr-auxiliary-partner          ok
                      symmetric-dr-auxiliary-relationship  warning
                      storage-failover-enabled             ok
                      has-intercluster-lif                 ok
                      node-object-limit                    ok
                      automatic-uso                        ok
clusA-02
                      node-reachable                       ok
                      local-ha-partner                     ok
                      dr-mirroring-on                      ok
                      automatic-uso                        ok
clusB-01
                      node-reachable                       ok
                      local-ha-partner                     ok
                      dr-mirroring-on                      ok
                      automatic-uso                        ok
clusB-02
                      node-reachable                       ok
                      local-ha-partner                     ok
                      dr-mirroring-on                      ok
                      automatic-uso                        ok
64 entries were displayed.
The following example shows the execution of the command with the -instance parameter:
clusA::> metrocluster check node show -instance
Node Name: clusA-01
                        Type of Check: node-reachable
                         Cluster Name: clusA
                  Result of the Check: ok
Additional Information/Recovery Steps:
Node Name: clusA-01
                        Type of Check: metrocluster-ready
                         Cluster Name: clusA
Node Name: clusA-01
                        Type of Check: local-ha-partner
                         Cluster Name: clusA
Node Name: clusA-01
                        Type of Check: ha-mirroring-on
                         Cluster Name: clusA
                  Result of the Check: warning
Additional Information/Recovery Steps: Node's HA mirroring is not active. Enable it on using "storage failover" commands.
Node Name: clusA-01
                        Type of Check: ha-mirroring-op-state
                         Cluster Name: clusA
Node Name: clusA-01
                        Type of Check: symmetric-ha-relationship
                         Cluster Name: clusA
Additional Information/Recovery Steps: Partner not found. Check if node "clusA-01's HA partner" is configured in MetroCluster.
Node Name: clusA-01
                        Type of Check: remote-dr-partner
                         Cluster Name: clusA
Node Name: clusA-01
                        Type of Check: dr-mirroring-on
                         Cluster Name: clusA
Node Name: clusA-01
                        Type of Check: dr-mirroring-op-state
                         Cluster Name: clusA
Node Name: clusA-01
                        Type of Check: symmetric-dr-relationship
                         Cluster Name: clusA
Node Name: clusA-01
                        Type of Check: remote-dr-auxiliary-partner
                         Cluster Name: clusA
Node Name: clusA-01
                        Type of Check: symmetric-dr-auxiliary-relationship
                         Cluster Name: clusA
Additional Information/Recovery Steps: Partner not found. Check if node "clusA-01's DR auxiliary partner" is configured in MetroCluster.
Node Name: clusA-01
                        Type of Check: storage-failover-enabled
                         Cluster Name: clusA
Additional Information/Recovery Steps: Node's storage failover is disabled.  Enable using "storage failover" commands.
Node Name: clusA-01
                        Type of Check: has-intercluster-lif
                         Cluster Name: clusA
Node Name: clusA-01
                        Type of Check: node-object-limit
                         Cluster Name: clusA
Node Name: clusB-01
                         Cluster Name: clusB
Node Name: clusB-01
                         Cluster Name: clusB
Node Name: clusB-01
                         Cluster Name: clusB
Node Name: clusB-01
                         Cluster Name: clusB
Node Name: clusB-01
                         Cluster Name: clusB
Node Name: clusB-01
                         Cluster Name: clusB
Additional Information/Recovery Steps: Partner not found. Check if node "clusB-01's HA partner" is configured in MetroCluster.
Node Name: clusB-01
                         Cluster Name: clusB
Node Name: clusB-01
                         Cluster Name: clusB
Node Name: clusB-01
                         Cluster Name: clusB
Node Name: clusB-01
                         Cluster Name: clusB
Node Name: clusB-01
                         Cluster Name: clusB
Node Name: clusB-01
                         Cluster Name: clusB
Additional Information/Recovery Steps: Partner not found. Check if node "clusB-01's DR auxiliary partner" is configured in MetroCluster.
Node Name: clusB-01
                         Cluster Name: clusB
Node Name: clusB-01
                         Cluster Name: clusB
Node Name: clusB-01
                         Cluster Name: clusB
Node Name: clusB-01
                        Type of Check: automatic-uso
                         Cluster Name: clusB
32 entries were displayed.
