The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage pool rename
PDF of this doc site
Creating your file...
Your file is ready
Rename storage pool
The storage pool rename
command changes the name of the storage pool.
-storage-pool <storage pool name>
- Storage Pool Name-
This parameter specifies the storage pool name.
-new-name <storage pool name>
- New Name of the Storage Pool-
This parameter specifies the new name of the storage pool.
Renaming storage pool "sp1" to "sp2"
cluster-1::> storage pool show Storage Storage Pool Type #Disks Nodes Total Size ------------------- ------- ------ ---------------- ---------- sp1 SSD 4 node-a, 10.44GB node-b cluster-1::> storage pool rename -storage-pool sp1 -new-name sp2 cluster-1::> storage pool show Storage Storage Pool Type #Disks Nodes Total Size ------------------- ------- ------ ---------------- ---------- sp2 SSD 4 node-a, 10.44GB node-b
