The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
lun import prepare-to-downgrade
PDF of this doc site
Creating your file...
Your file is ready
Prepares LUN import to be downgraded
This command prepares the cluster for a downgrade to a version of Data ONTAP earlier than 8.3.1 by disabling the online LUN import feature. Before using this command verify that all LUNs in an import relationships are offline by running lun show .
cluster1::> lun import prepare-to-downgrade
The above example will disable the online LUN import feature if all LUNs in import relationships are offline
