ONTAP commands
lun import prepare-to-downgrade
Prepares LUN import to be downgraded
This command prepares the cluster for a downgrade to a version of ONTAP earlier than 8.3.1 by disabling the online LUN import feature. Before using this command verify that all LUNs in an import relationships are offline by running lun show .
cluster1::> lun import prepare-to-downgrade
The above example will disable the online LUN import feature if all LUNs in import relationships are offline
