system service-processor log show-allocations
PDF of this doc site
Creating your file...
Display the Service Processor log allocation map
The system service-processor log show-allocations
command displays the allocation map of the Service Processor logs collected in the cluster. The Service Processor logs of a node are archived in the mroot directory of the collecting node. This command displays the sequence numbers for the Service Processor log files that reside in each collecting node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
If you specify this parameter, the command displays the sequence numbers of Service Processor log files that the specified node has collected.
[-remote-node <text>]
- Remote Node-
If you specify this parameter, the command displays the sequence numbers of Service Processor log files that have been collected from the specified remote node.
[-seqList <integer>,…]
- Log File Sequence Numbers-
If you specify this parameter, the command displays information about Service Processor log files with the specified sequence number.
The following example displays the allocation map of the Service Processor log files in the cluster.
cluster1::> system service-processor log show-allocation Node From Which Node Log File Sequence ------------------- ------------------- ---------------------------------- cluster1-01 cluster1-01 10, 11, 12, 13, 15 cluster1-02 14, 15, 16, 17 cluster1-02 cluster1-01 14 cluster1-02 11, 12, 13 4 entries were displayed. cluster1::>
