ONTAP commands
system service-processor log show-allocations
Display the Service Processor log allocation map
The system service-processor log show-allocations command displays the allocation map of the Service Processor logs collected in the cluster. The Service Processor logs of a node are archived in the mroot directory of the collecting node. This command displays the sequence numbers for the Service Processor log files that reside in each collecting node.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If you specify this parameter, the command displays the sequence numbers of Service Processor log files that the specified node has collected.
[-remote-node <text>] - Remote Node
If you specify this parameter, the command displays the sequence numbers of Service Processor log files that have been collected from the specified remote node.
[-seqList <integer>,…​] - Log File Sequence Numbers
If you specify this parameter, the command displays information about Service Processor log files with the specified sequence number.
The following example displays the allocation map of the Service Processor log files in the cluster.
cluster1::> system service-processor log show-allocation
Node                From Which Node     Log File Sequence
cluster1-01
                    cluster1-01         10, 11, 12, 13, 15
                    cluster1-02         14, 15, 16, 17
cluster1-02
                    cluster1-01         14
                    cluster1-02         11, 12, 13
4 entries were displayed.
cluster1::>
