volume make-vsroot
Designate a non-root volume as a root volume of the Vserver
The volume make-vsroot
command promotes a non-root volume of the Vserver to be the Vserver’s root volume. The Vserver’s root volume must be a FlexVol volume with a size of atleast 1 GB.
For instance, if you run this command on a volume named user
that is located on a Vserver named vs0
, the volume user
is made the root volume of the Vserver vs0
This command is available only at the advanced privilege level and higher.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver on which a non-root volume is to be made the root volume.
-volume <volume name>
- Volume Name-
This specifies the non-root volume that is to be made the root volume of its Vserver. This must be an existing FlexVol volume. Using a SnapLock volume as the root volume for a Vserver is not supported.
The following example makes a volume named root_vs0_backup
the root volume of its Vserver with FlexVol volumes, which is named vs0
node::> volume make-vsroot -vserver vs0 -volume root_vs0_backup
The following example makes a volume named root_vs1
the root volume of the Vserver with Infinite Volume vs1
node::> volume make-vsroot -vserver vs1 -volume root_vs1 -aggregate aggr1
