The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network subnet delete
PDF of this doc site
Creating your file...
Your file is ready
Delete an existing subnet object
Delete a subnet that contains no ports.
-ipspace <IPspace>
- IPspace Name-
The IPspace to which the subnet belongs.
-subnet-name <subnet name>
- Subnet Name-
The name of the subnet to be deleted.
[-force-update-lif-associations <true>]
- Change the subnet association-
This command will fail if the subnet has ranges containing any existing service processor interface or network interface IP addresses. Setting this value to true will remove the network interface associations with the subnet and allow the command to succeed. However, it will not affect service processor interfaces.
The following example deletes subnet s1
in IPspace Default
cluster1::> network subnet delete -ipspace Default -subnet-name s1
