The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver cifs users-and-groups privilege reset-privilege
PDF of this doc site
Creating your file...
Your file is ready
Reset local privileges for a user or group
The vserver cifs users-and-groups privilege reset-privilege
command resets privileges of a local or Active Directory user or group.
-vserver <vserver name>
- Vserver-
This specifies the name of the Vserver.
-user-or-group-name <CIFS name>
- User or Group Name-
This specifies the name of the local or Active Directory user or group.
The following example resets the privileges for the local user "CIFS_SERVER\u1". This operation removes the privilege entry, if any, associated with the local user "CIFS_SERVER\u1".
cluster1::> vserver cifs users-and-groups privilege show Vserver User or Group Name Privileges -------------- ---------------------------- ------------------- vs1 CIFS_SERVER\u1 SeTakeOwnershipPrivilege SeRestorePrivilege cluster1::> vserver cifs users-and-groups privilege reset-privilege -vserver vs1 -user-or-group-name CIFS_SERVER\u1 cluster1::> vserver cifs users-and-groups privilege show This table is currently empty.
+ + The following example resets the privileges for the group "BUILTIN\Administrators", effectively removing the privilege entry.
cluster1::> vserver cifs users-and-groups privilege show Vserver User or Group Name Privileges -------------- ---------------------------- ------------------- vs1 BUILTIN\Administrators SeRestorePrivilege SeSecurityPrivilege SeTakeOwnershipPrivilege cluster1::> vserver cifs users-and-groups privilege reset-privilege -vserver vs1 -user-or-group-name BUILTIN\Administrators cluster1::> vserver cifs users-and-groups privilege show This table is currently empty.
