The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage aggregate inode-upgrade resume
PDF of this doc site
Creating your file...
Your file is ready
Resume suspended inode upgrade
The storage aggregate inode-upgrade resume
command resumes a suspended inode upgrade process. The inode upgrade process might have been suspended earlier due to performance reasons.
-node {<nodename>|local}
- Node Name (privilege: advanced)-
If this parameter is specified, the command resumes the upgrade process of an aggregate that is located on the specified node.
-aggregate <aggregate name>
- Aggregate Name (privilege: advanced)-
This specifies the aggregate for which the inode upgrade process is to be resumed.
The following example resumes an aggregate upgrade process:
cluster1::> storage aggregate inode-upgrade resume -aggregate aggr1
