The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage tape reset
PDF of this doc site
Creating your file...
Your file is ready
Reset a tape drive
This command resets a specified tape drive.
-node {<nodename>|local}
- Node (privilege: advanced)-
Use this parameter to specify the node to which the tape drive is attached.
-device-id <text>
- Tape Drive Device ID (privilege: advanced)-
Use this parameter to specify the device ID of the tape drive is to be reset.
The following example resets the tape drive with device ID sw4:2.126L3 attached to the node, cluster1-01.
cluster1::> storage tape reset -node cluster1-01 -device-id sw4:2.126L3
