The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver active-directory delete
PDF of this doc site
Creating your file...
Your file is ready
Delete an Active Directory account
The vserver active-directory delete
command deletes the Active Directory account for a specified Vserver.
-vserver <vserver>
- Vserver-
This parameter specifies the Vserver for the Active Directory account you want to delete.
The following example deletes the Active Directory account for a Vserver named vs1
cluster1::> vserver active-directory delete -vserver vs1 In order to delete an Active Directory machine account, you must supply the name and password of a Windows account with sufficient privileges to remove computers from the "example.com" domain. Enter the user name: Administrator Enter the password:
