ONTAP commands
vserver nvme show
Show NVMe service configuration
The vserver nvme show command displays the current status of the NVMe service in a cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Use this parameter to display the NVMe services that match the Vserver that you specify.
[-status-admin {down|up}] - Administrative Status
Use this parameter to display the NVMe services that match the administrative status that you specify.
cluster1::*> vserver nvme show
Vserver    Status Admin
vs1        up
vs2        up
2 entries were displayed.
