ONTAP commands
snaplock legal-hold begin
Starts an operation to place files under legal-hold in the user specified path on a SnapLock compliance volume.
The snaplock legal-hold begin command is used to place specified file or files under legal-hold for a given litigation. Only a user with security login role vsadmin-snaplock is allowed to perform this operation.
-vserver <vserver name> - Vserver Name
Specifies the name of the Vserver which owns the volume. The specified file or files to be placed under legal-hold reside on this volume.
-litigation-name <text> - Litigation Name
Specifies the name of the litigation for which the file or files have to be placed under legal-hold.
-volume <volume name> - Volume
Specifies the name of the SnapLock compliance volume on which the file or files to be placed under legal-hold reside.
-path <text> - Path
Specifies a path relative to the volume root. The path can be either a file path of the single file to be placed under legal-hold or a directory path where all regular files under it must be placed under legal-hold.
The following example starts a legal-hold begin operation on file file1 in volume slc_vol1 :
vs1::> snaplock legal-hold begin -litigation-name litigation1 -volume slc_vol1 -path /file1
SnapLock legal-hold begin operation is queued. Run "snaplock legal-hold show -operation-id 16842773 -instance" to view the operation status.
The following example starts a legal-hold begin operation on all files in the volume slc_vol1 :
SnapLock legal-hold begin operation is queued. Run "snaplock legal-hold show -operation-id 16842775 -instance" to view the operation status.
Looking for answers?
Try Doc, our Gen AI Assistant.
