network options port-health-monitor enable-monitors
PDF of this doc site
Creating your file...
Enable one or more port health monitors
This command enables the given port health monitors for the given IPspaces in the cluster.
-ipspace <IPspace>
- IPspace Name (privilege: advanced)-
The name of the IPspace for which the specified port health monitors are enabled.
-health-monitors {l2-reachability|link-flapping|crc-errors|vswitch-link}
- List of Port Health Monitors to Enable (privilege: advanced)-
The port health monitors to enable. Upon enabling the
l2_reachability
health monitor, it runs in an "unpromoted" state. While in this state, the monitor does not mark any ports as unhealthy due to the l2_reachability health check. The monitor is promoted in the "Cluster" IPspace when the "Cluster" broadcast domain is found to have passed thel2_reachability
health check. An EMS event called "vifmgr.hm.promoted" event is generated when the health monitor is promoted for the IPspace.
The following example enables the "l2_reachability" health monitor for the "Default" IPspace:
The status of the "link_flapping" monitor is unaffected by the command. |
cluster1::*> network options port-health-monitor show IPspace Enabled Port Health Monitors ------------- ---------------------------- Cluster l2_reachability, link_flapping Default link_flapping 2 entries were displayed. cluster1::*> network options port-health-monitor enableMonitors -ipspace Default -health-monitors l2_reachability cluster1::*> network options port-health-monitor show IPspace Enabled Port Health Monitors ------------- ---------------------------- Cluster l2_reachability, link_flapping Default l2_reachability, link_flapping 2 entries were displayed.
