network fcp topology show
FCP topology interconnect elements per adapter
Display FCP topology interconnect elements per adapter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Use this parameter to select the interconnect elements for adapters that are located on the node that you specify.
[-adapter <text>] - Adapter
Use this parameter to select the interconnect elements for the specified adapter.
[-domain-id <integer>] - Domain Id
Use this parameter to select the interconnect elements with the specified domain identifier.
[-port-wwpn <text>] - Port WWPN
Use this parameter to select the interconnect elements with the specified port world wide name.
[-switch-name <text>] - Switch Name
Use this parameter to select the interconnect elements with the specified switch.
[-switch-vendor <text>] - Switch Vendor
Use this parameter to select the interconnect elements with the specified vendor.
[-switch-release <text>] - Switch Release
Use this parameter to select the interconnect elements with the specified release.
[-switch-wwn <text>] - Switch WWN
Use this parameter to select the interconnect elements with the specified world wide name.
[-port-count <integer>] - Port Count
Use this parameter to select the interconnect elements with the specified port count.
[-port-slot <text>] - Port Slot
Use this parameter to select the interconnect elements with the specified port slot.
[-port-state {Unknown|Online|Offline|Testing|Fault}] - Port State
Use this parameter to select the interconnect elements with the specified port state.
[-port-type {None|N-Port|NL-Port|FNL-Port|NX-Port|F-Port|FL-Port|E-Port|B-Port|TNP-Port|TF-Port|NV-Port|FV-Port|SD-Port|TE-Port|TL-Port}] - Port Type
Use this parameter to select the interconnect elements with the specified port type.
[-port-attached-wwpn <text>] - Attached Port WWPN
Use this parameter to select the interconnect elements with the specified attached wwpn.
[-port-attached-id <text>] - Attached Port Id
Use this parameter to select the interconnect elements with the specified attached id.
[-port-attached-visible <text>] - Visible
Use this parameter to select the interconnect elements with the specified visiblity flag on attached port structure.
cluster1::> network fcp topology show
Switch connected to the adapter 0c
      Switch Name: ssan-fc0e-d58
    Switch Vendor: Cisco Systems, Inc.
   Switch Release: 5.2(1)N1(9)
    Switch Domain: 4
       Switch WWN: 20:05:00:05:9b:26:f4:c1
       Port Count: 20
Port    Port WWN                State     Type      Attached WWPN           Port Id
vfc9    20:08:00:05:9b:26:f4:ff Offline   None      -                       -
vfc10   20:15:00:05:9b:26:f4:ff Online    TF-Port   50:0a:09:82:8d:92:4c:ff 0x0407c0  *
vfc11   20:16:00:05:9b:26:f4:ff Online    TF-Port   50:0a:09:81:8d:e2:4e:ec 0x040800  *
    Switch Domain: 4
       Port Count: 20
vfc20   20:13:00:05:9b:26:f4:ff Offline   None      -                       -
vfc21   20:14:00:05:9b:26:f4:ff Online    TF-Port   50:0a:09:81:8d:92:4c:ff 0x0407a0  *
5 entries were displayed.
The example above show FCP topology interconnect information for the cluster.
