event catalog show
Display event definitions
The event catalog show
command displays information about events in the catalog. By default, this command displays the following information:
Message name of the event
Severity of the event
SNMP trap type of the event
To display detailed information about a specific event, run the command with the -message-name
parameter, and specify the name of the event. The detailed view adds the following information:
Full description of the event
Action to be taken to address the event
Event's deprecation status
You can specify additional parameters to limit output to the information that matches those parameters. For example, to display information only about events with an event name that begins with raid
, enter the command with the -message-name
raid*
parameter. The parameter value can either be a specific text string or a wildcard pattern.
Alternatively, an event filter can also be specified to limit the output events.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-message-name <Message Name>]
- Message Name-
Selects the events that match this parameter value.
[-filter-name <text>]
- Filter Name-
Selects the events that match this parameter value. The parameter value indicates an existing filter name that, when applied permits the inclusion of the listed events.
[-severity {EMERGENCY|ALERT|ERROR|NOTICE|INFORMATIONAL|DEBUG}]
- Severity-
[-description <text>]
- Description-
[-action <text>]
- Corrective Action-
[-snmp-trap-type {Standard|Built-in|Severity-based}]
- SNMP Trap Type-
Selects the events that match this parameter value. The parameter value describes the type of SNMP trap associated with the event. The value can be one of the following:
Standard
trap type events are those defined in the RFCs.Built-in
trap types are those that are NetApp Enterprise traps specific to events. The remaining events are considered to haveSeverity-based
SNMP trap types. [-deprecated {true|false}]
- Is Deprecated-
Selects the events that match this parameter value. The parameter value indicates whether the event is deprecated or not.
Deprecated events may be removed in a future release of Data ONTAP.
The following example displays the event catalog:
cluster1::> event filter show -filter-name filter1 Filter Name Rule Rule Message Name SNMP Trap Type Severity Position Type ----------- -------- --------- ---------------------- --------------- -------- filter1 1 include zapi.* * * 2 exclude * * * 2 entries were displayed. cluster1::> event catalog show -filter-name filter1 Message Severity SNMP Trap Type -------------------------------- ---------------- ----------------- zapi.killed NOTICE Severity-based zapi.method.notfound NOTICE Severity-based zapi.sf.up.ready INFORMATIONAL Severity-based zapi.snapshot.success NOTICE Severity-based zapi.streamout.noMethod NOTICE Severity-based 5 entries were displayed. cluster1::> event catalog show -message-name zsm.* -filter-name filter1 There are no entries matching your query. cluster1::> event catalog show -message-name zapi.* -filter-name filter1 Message Severity SNMP Trap Type -------------------------------- ---------------- ----------------- zapi.method.notfound NOTICE Severity-based zapi.sf.up.ready INFORMATIONAL Severity-based zapi.snapshot.success NOTICE Severity-based zapi.streamout.noMethod NOTICE Severity-based 4 entries were displayed. cluster1::> event catalog show -message-name CR.* Message Severity SNMP Trap Type -------------------------------- ---------------- ----------------- CR.Corrupt.Redir.Deleted INFORMATIONAL Severity-based CR.Dangling.Redir.Deleted INFORMATIONAL Severity-based CR.Data.File.Inaccessible NOTICE Severity-based CR.Del.Corrupt.Redir.Failed NOTICE Severity-based CR.Del.CrptStreamData.Fail NOTICE Severity-based CR.Del.CrptStreamRedir.Fail NOTICE Severity-based CR.Del.DangStreamData.Fail NOTICE Severity-based CR.Del.DangStreamRedir.Fail NOTICE Severity-based CR.Del.Dangling.Redir.Failed NOTICE Severity-based CR.Fix.Corrupt.Redir.Failed NOTICE Severity-based CR.Fix.Crpt.Data.Dir.Failed INFORMATIONAL Severity-based CR.Fix.Crpt.Data.File.Failed NOTICE Severity-based CR.Fix.CrptStreamRedir.Fail NOTICE Severity-based CR.Fix.Dang.Data.File.Failed NOTICE Severity-based CR.Fix.Nlinks.Failed NOTICE Severity-based CR.Fix.TempFiles.Failed INFORMATIONAL Severity-based CR.Max.Session.Exceed INFORMATIONAL Severity-based CR.RDB.Counters.Not.Updated INFORMATIONAL Severity-based CR.RDB.State.Not.Updated NOTICE Severity-based CR.Redir.File.Inaccessible NOTICE Severity-based CR.Snapshot.Not.Deleted NOTICE Severity-based Message Severity SNMP Trap Type -------------------------------- ---------------- ----------------- CR.Sync.ACL.Fail NOTICE Severity-based 22 entries were displayed. cluster1::> event catalog show -instance ... ... Message Name: Nblade.cifsEncSessAccessDenied Severity: ERROR Description: This message occurs when a client not capable of SMB encryption tries to establish a CIFS session that requires SMB encryption. Corrective Action: Either ensure that the client is capable of SMB encryption or disable SMB encryption on the Vserver. SNMP Trap Type: Severity-based Is Deprecated: false Message Name: Nblade.cifsEncShrAccessDenied Severity: ERROR Description: This message occurs when a client not capable of SMB encryption tries to connect to a CIFS share that requires SMB encryption. Corrective Action: Either ensure that the client is capable of SMB encryption or disable SMB encryption on the CIFS share. SNMP Trap Type: Severity-based Is Deprecated: false ... ...
