system ha interconnect ood enable-optimization
Enable coalescing work requests
The system ha interconnect ood enable-optimization
command enables you to turn on optimization (coalescing out-of-order delivery requests) on the high-availability interconnect device. This command is only supported on FAS2500 series nodes in the cluster.
-node <nodename>
- Node-
This mandatory parameter specifies which node will have the optimization enabled. The value "local" specifies the current node.
cluster1::*> system ha interconnect ood enable-optimization -node ic-f2554-03
