lun bind show
PDF of this doc site
Creating your file...
Show list of Vvol bindings
Shows the configured VVol to protocol endpoint bindings.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name (privilege: advanced)-
Selects the bindings that match this parameter value.
[-protocol-endpoint-msid <integer>]
- PE MSID (privilege: advanced)-
[-protocol-endpoint-vdisk-id <text>]
- PE Vdisk ID (privilege: advanced)-
[-vvol-msid <integer>]
- VVol MSID (privilege: advanced)-
[-vvol-vdisk-id <text>]
- VVol Vdisk ID (privilege: advanced)-
[-vserver-uuid <UUID>]
- Vserver UUID (privilege: advanced)-
[-protocol-endpoint-path <path>]
- Protocol Endpoint (privilege: advanced)-
Selects the bindings that match this parameter value. Examples of correct LUN paths are
/vol/vol1/lun1
and/vol/vol1/qtree1/lun1
. [-protocol-endpoint-node <nodename>]
- PE Node (privilege: advanced)-
[-vvol-path <path>]
- VVol (privilege: advanced)-
/vol/vol1/lun1
. [-vvol-node <nodename>]
- VVol Node (privilege: advanced)-
[-secondary-lun <Hex 64bit Integer>]
- Secondary LUN (privilege: advanced)-
[-is-optimal {true|false}]
- Optimal binding (privilege: advanced)-
[-reference-count <integer>]
- Reference Count (privilege: advanced)-
cluster1::*> lun bind show -vserver vs1 Vserver Protocol Endpoint Node Vvol LUN Secondary LUN Optimal? -------------- -------------------------------------- -------------- -------- vs1 /vol/VV1/PE1 cluster-node1 /vol/VV2/30dfab d20000010000 false /vol/VV3/234ace d20000020000 true /vol/VV3/234acf d20000030000 true /vol/VV2/PE2 cluster-node2 /vol/VV2/30dfab d20000010000 true 4 entries were displayed.
The example above displays all the LUN bindings on Vserver vs1.
