network ndp neighbor create
Create a static NDP neighbor entry
The network ndp neighbor create
command creates a static Neighbor Discovery Protocol (NDP) neighbor entry within a Vserver.
-vserver <vserver name>
- Vserver Name-
Use this parameter to specify the Vserver on which the NDP neighbor is to be created.
-neighbor <IP Address>
- Neighbor Address-
Use this parameter to specify the neighbor’s IPv6 address.
-mac-address <MAC Address>
- MAC Address-
Use this parameter to specify the neighbor’s MAC address.
The following example creates a NDP neighbor entry within Vserver vs0.
cluster1::*> network ndp neighbor create -vserver vs0 -neighbor 20:20::20 -mac-address 10:10:10:0:0:1
