system feature-usage show-history
Display Feature Usage History
Display feature usage information in the cluster on a per-node and per-week basis.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Displays feature usage information for the specified node name.
[-serial-number <Node Serial Number>] - Node Serial Number
Displays feature usage information for the specified serial number.
[-feature-name <Managed Feature>] - Feature Name
Displays feature usage information for the specified feature name.
[-week-number <Sequence Number>] - Week Number
Displays feature usage information for the specified week number.
[-usage-status {not-used|configured|in-use|not-available}] - Usage Status
Displays feature usage information that matches the specified usage status.
[-date-collected <MM/DD/YYYY HH:MM:SS>] - Collection Date
Displays feature usage information that is collected on the day matching the specified date.
[-owner <text>] - Owner
Displays feature usage information for the specified owner name.
[-feature-message <text>] - Feature Message
Displays feature usage information that contains the specified feature message.
The following example displays a usage output filtered by the serial number and feature name:
cluster1::> system feature-usage show-history -serial-number 1-81-0000000000000001122334455 -feature-name NFS
Node Serial Number: 1-81-0000000000000001122334455
Feature Name: NFS
Owner: node1
Week # Usage Status      Date Collected       Feature Message
     4 in-use            01/22/13 10:00:00
     3 in-use            01/15/13 10:00:00
     2 not-used          01/08/13 10:00:00
     1 configured        01/01/13 10:00:00
4 entries were displayed.
