The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver nfs kerberos realm delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a Kerberos realm configuration
The vserver nfs kerberos realm delete
command deletes a Kerberos realm configuration from the system.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver for the Kerberos realm configuration that you want to delete.
-realm <text>
- Kerberos Realm-
This parameter specifies the name of the Kerberos realm for the configuration.
The following example deletes the Kerberos realm SEC.EXAMPLE.COM from the Vserver named AUTH:
cluster1::> vserver nfs kerberos realm delete -vserver AUTH -realm SEC.EXAMPLE.COM
