The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network port vlan delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a virtual LAN (VLAN)
The network port vlan delete
command deletes a VLAN from a network port.
When you delete a VLAN port, it is automatically removed from all failover rules and groups that use it. |
-node {<nodename>|local}
- Node-
The node from which the VLAN is to be deleted.
-vlan-name {<netport>|<ifgrp>}
- VLAN Name -
The name of the VLAN that is to be deleted
-port {<netport>|<ifgrp>}
- Associated Network Port -
The network port to which the VLAN is to be attached.
-vlan-id <integer>
- Network Switch VLAN Identifier }-
The ID tag of the deleted VLAN.
This example shows how to delete VLAN e1c-80 from network port e1c on node1.
cluster1::> network port vlan delete -node node1 -vlan-name e1c-80
