The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage aggregate reallocation restart
PDF of this doc site
Creating your file...
Your file is ready
Restart reallocate job on aggregate
Starts a reallocation job. Use this command to restart a quiesced (temporarily stopped) job or a scheduled scan that is idle for the aggregate.
-aggregate <aggregate name>
- Aggregate Name-
Specifies the aggregate on which you want to restart reallocation scans.
[-i, -ignore-checkpoint <true>]
- Ignore Checkpoint-
Restarts the job at the beginning when set to true. If you use this command without specifying this parameter, its effective value is false and the job starts the scan at the point where it was stopped. If you specify this parameter without a value, it is set to true and the scan restarts at the beginning.
cluster1::> storage aggregate reallocation restart -aggregate aggr0 -ignore-checkpoint true
Restarts reallocation job on aggregate aggr0 from the beginning.
