The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
snaplock event-retention policy delete
PDF of this doc site
Creating your file...
Your file is ready
Delete SnapLock Event Based Retention policies for a Vserver
The snaplock event-retention policy delete
command is used to delete Event Based Retention (EBR) policies for a Vserver. Only a user with security login role vsadmin-snaplock
is allowed to perform this operation.
-vserver <vserver name>
- Vserver Name-
If this parameter is specified, the command deletes all EBR policies that match the specified Vserver.
-name <text>
- Policy Name-
name
The following example deletes retention policy "p1" for Vserver "vs1":
vs1::> snaplock event-retention policy delete -name p1
