The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver smtape break
PDF of this doc site
Creating your file...
Your file is ready
Make a restored volume read-write
This command breaks the relationship between the tape backup of a volume and a restored volume, changing the restored volume from read-only to read/write.
-vserver <vserver name>
- Vserver Name-
Use this parameter to specify the Vserver name on which the volume is located.
-volume <volume name>
- Volume Name-
Use this parameter to specify the name of the read-only volume that needs to be changed into a read/writeable volume after an smtape restore.
Make the read-only volume datavol
on Vserver vserver0
writeable after a restore.
cluster1::> vserver smtape break -vserver vserver0 -volume datavol [Job 84] Job succeeded: SnapMirror Break Succeeded
