vserver smtape break
Make a restored volume read-write
This command breaks the relationship between the tape backup of a volume and a restored volume, changing the restored volume from read-only to read/write.
-vserver <vserver name>- Vserver Name-
Use this parameter to specify the Vserver name on which the volume is located.
-volume <volume name>- Volume Name-
Use this parameter to specify the name of the read-only volume that needs to be changed into a read/writeable volume after an smtape restore.
Make the read-only volume datavol on Vserver vserver0 writeable after a restore.
cluster1::> vserver smtape break -vserver vserver0 -volume datavol [Job 84] Job succeeded: SnapMirror Break Succeeded
