vserver cifs domain preferred-dc check
Display validation status of the Preferred-DC configuration
Use the vserver cifs domain preferred-dc check command to check the status of configured preferred DC on a particular vserver.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. -vserver <vserver>- Vserver-
Use this parameter to specify the Vserver whose preferred DC needs to be validated.
[-server-ip <text>,…]- DC Address-
Use this parameter to display IP-address of the configured CIFS Preferred-DC servers.
[-domain <TextNoCase>,…]- Domain Name-
Use this parameter to display Domain name of the configured CIFS Preferred-DCs.
[-status {down|up}]- DC Status-
Use this parameter to display information only about CIFS Preferred-DC servers with a status that matches the value you specify.
[-status-details <text>,…]- Status Details-
Use this parameter to display information only about CIFS Preferred-DC servers with status details that match the value you specify.
The following example checks the connectivity of preferred DC on vserver vs0.
cluster1::> vserver cifs domain preferred-dc check -vserver vs0 Vserver : vs0 Domain Name DC Address Status Status Details ----------- ----------- ------ -------------- example.com 1.1.1.1 up Response time (msec): 426 example.com 1.1.1.2 up Response time (msec): 425 example1.com 2.2.2.2 up Response time (msec): 423 example2.com 3.3.3.3 up Response time (msec): 422
