protection-type show
Display the supported protection types and available RPOs
This command displays the protection types available for application provisioning.
[-fields <fieldname>,…] -
Specifies fields that you want included in the output. You can use
-fields ?to display the available fields. - |
[-instance ]} -
Specifies the display of all available fields for each selected protection type.
[-vserver <vserver name>]- Vserver (privilege: advanced)-
Selects the protection types of Vservers that match the parameter value.
[-protection-type {local|remote}]- Protection Type (privilege: advanced)-
Selects the protection types that match the parameter value.
[-rpo-list <text>,…]- List of available RPOs (privilege: advanced)-
Selects the protection types whose list of available RPOs matches the parameter value.
[-rpo-list-description <text>,…]- List of descriptions of available RPOs (privilege: advanced)-
Selects the protection types whose list of description of available RPOs matches the parameter value.
[-description <text>]- Description of Protection Type (privilege: advanced)-
Selects the protection types with a description that matches the parameter value.
The following example displays the protection types and the associated available RPOs for all Vservers in the cluster.
cluster1::*> protection-type show
Vserver Protection Type RPO List
vs1
local hourly, none
remote none
vs2
local hourly, none
remote none, zero
