The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume snapshot policy remove-schedule
PDF of this doc site
Creating your file...
Your file is ready
Remove a schedule from snapshot policy
The volume snapshot policy remove-schedule
command removes a schedule from a Snapshot policy.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver on which a Snapshot policy schedule is to be removed.
-policy <snapshot policy>
- Snapshot Policy Name-
This specifies the Snapshot policy from which a schedule is to be removed.
-schedule <text>
- Schedule Name-
This specifies the schedule that is to be removed from the Snapshot policy.
The following example removes a schedule named hourly from a Snapshot policy named snappolicy_daily on Vserver vs0:
cluster1::> volume snapshot policy remove-schedule -vserver vs0 -policy snappolicy_daily -schedule hourly
