ONTAP commands
volume snapshot policy remove-schedule
Remove a schedule from snapshot policy
The volume snapshot policy remove-schedule command removes a schedule from a snapshot policy.
-vserver <vserver name> - Vserver Name
This specifies the Vserver on which a snapshot policy schedule is to be removed.
-policy <snapshot policy> - Snapshot Policy Name
This specifies the snapshot policy from which a schedule is to be removed.
-schedule <text> - Schedule Name
This specifies the schedule that is to be removed from the snapshot policy.
The following example removes a schedule named hourly from a snapshot policy named snappolicy_daily on Vserver vs0:
cluster1::> volume snapshot policy remove-schedule -vserver vs0 -policy snappolicy_daily -schedule hourly
