cluster add-node-status
PDF of this doc site
Creating your file...
Show cluster expansion progress
The cluster add-node-status
command displays the progress of the node joining a cluster initiated by using the cluster create command or the cluster add-node command
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node-uuid <UUID>]
- Node UUID-
Select the node that match the specified node UUID.
[-node-name <text>]
- Node Name-
Select the nodes that match the specified node name.
[-cluster-ip <IP Address>]
- IP Address of a Cluster Interface of Node-
Select the nodes that match the specified cluster IP.
[-status <Cluster Operation Status>]
- The Status of Current Task Being Performed-
Select the nodes that match the specified status. This status shows whether the operation is ongoing or complete with success or failure. The various phases that a node goes through are node-initialization, joining-cluster, service-startup, post-cluster-setup and success or failure.
[-failure-msg <text>]
- Error Reason-
Select the nodes that match the specified error string.
[-last-updated <MM/DD/YYYY HH:MM:SS>]
- Last Updated-
The date/time stamp of the last update to the status.
The following example shows the progress of a node add operation:
clus1::> cluster add-node-status Node Name Node IP Status Error Reason --------------- ----------------- -------------- ---------------------- node1 1.1.1.1 success -
