network bgp peer-group show
Display BGP peer groups information
The network bgp peer-group show command displays the BGP peer groups configuration.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-ipspace <IPspace>]- IPspace Name-
This parameter selects peer groups that match the specified IPspace.
[-peer-group <text>]- Peer Group Name-
This parameter selects peer groups that match the specified name.
[-bgp-lif <lif-name>]- BGP LIF-
This parameter selects peer groups that match the specified BGP Interface.
[-peer-address <IP Address>]- Peer Router Address-
This parameter selects peer groups that match the specified peer router address.
[-peer-asn <integer>]- Peer Router Autonomous number-
This parameter selects peer groups that match the specified autonomous system number.
[-state <BGP Session State>]- Peer Group State-
This parameter selects peer groups that match the specified BGP session state.
[-bgp-node <nodename>]- BGP LIF Node-
bgp-nodevalue. This value is calculated based on the current node of the corresponding BGP LIF. [-bgp-port <netport>]- BGP LIF Port-
bgp-portvalue. This value is calculated based on the current port of the associated BGP LIF. [-route-preference <integer>]- Route Preference-
This parameter selects peer groups that match the specified route preference value.
cluster1::> network bgp peer-group show
IPspace: Default
Peer Local BGP Peer router Autonomous
Group Interface Address/subnet state Number Node Port
gp1 bgp_lif1 10.0.5.37 up 10 node1 e1a
gp2 bgp_lif2 10.0.6.38 up 12 node1 e2a
