storage tape library path show-by-initiator
PDF of this doc site
Creating your file...
Display a list of LUNs on the given tape library
This command displays path information for every initiator port connected to a tape library. The output is similar to the storage library path show command but the output is listed by initiator.
[-fields <fieldname>,…]
fields used to be used in this display
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Controller name-
The name of the clustered node for which information is being displayed.
[-initiator <text>]
- Initiator Port-
Initiator port that the clustered node uses.
[-target-wwpn <text>]
- Target Port-
Target World Wide Port Name. Port on the storage tape library that is being used.
[-initiator-side-switch-port <text>]
- Initiator Side Switch Port-
Switch port connected to the clustered node.
[-target-side-switch-port <text>]
- Target Side Switch Port-
Switch port connected to the tape library.
[-array-name <array name>]
- Library Name-
Name of the storage tape library that is connected to the cluster.
[-tpgn <integer>]
- Target Port Group Number-
TPGN refers to the target port group to which the target port belongs. A target port group is a set of target ports which share the same LUN access characteristics and failover behaviors.
[-port-speed <text>]
- Port Speed-
Port Speed of the specified port.
[-path-io-kbps <integer>]
- Kbytes of I/O per second on Path (Rolling Average)-
Rolling average of Kbytes of I/O per second on the library path.
[-path-iops <integer>]
- Number of I/O per second on Path (Rolling Average)-
Rolling average of I/O per second on the library path.
[-initiator-io-kbps <integer>]
- Kbytes of I/O per second on Initiator (Rolling Average)-
Rolling average of Kbytes of I/O per second on the initiator port.
[-initiator-iops <integer>]
- Number of I/O per second on Initiator (Rolling Average)-
>Rolling average of I/O per second on the initiator port.
[-target-io-kbps <integer>]
- Kbytes of I/O per second to Target (Rolling Average)-
Rolling average of Kbytes of I/O per second on the target port.
[-target-iops <integer>]
- Number of I/O per second to Target (Rolling Average)-
Rolling average of I/O per second on the target port.
The following example displays the path information by initiator for a storage tape library.
cluster1::> storage tape library path show-by-initiator Node: cluster1-01 Initiator I/O Initiator Side Path I/O Target Side Target I/O Initiator (KB/s) Switch Port (KB/s) Switch Port (KB/s) Target Port Library Name --------- ------------- -------------------- ------------ -------------------- ------------ ---------------- ---------------- 0b 0 sw_tape:6 0 sw_tape:0 0 510a09800000412d TAPE_LIB_1 sw_tape:1 0 510a09820000412d TAPE_LIB_1 3d 0 N/A 0 N/A 0 50050763124b4d6f TAPE_LIB_2 3 entries were displayed.
