vserver cifs nbtstat
PDF of this doc site
Creating your file...
Display NetBIOS information over TCP connection
The vserver cifs nbtstat command displays information about NetBIOS over TCP (NBT) connections for the cluster. It displays the IP address associated with the interfaces, the IP addresses of the WINS servers in use, and information about the registered NetBIOS names for the cluster. You can use this command to troubleshoot NetBIOS name resolution problems.
NetBIOS name service (NBNS) over IPv6 is not supported. |
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified node.
[-vserver <vserver name>]
- Vserver-
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified Vserver.
[-nbt-name <text>]
- NBT Name-
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified NetBIOS name.
[-netbios-suffix <Hex String>]
- NetBIOS Suffix-
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified NetBIOS suffix.
[-interface <IP Address>,…]
- Interfaces-
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified IP address.
[-wins-servers <IP Address>,…]
- Servers-
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified WINS servers.
[-server-state <text>,…]
- Server State (active, inactive)-
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified WINS server state. The following are possible values for this parameter:
active
inactive
[-nbt-scope <text>]
- NBT Scope-
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified NetBIOS name scope.
[-nbt-mode <text>]
- NBT Mode-
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified NetBIOS name service mode. The following are possible values for this parameter:
'p' - Point to Point
'h' - Hybrid
'm' - Mixed
'b' - Broadcast
[-state <text>]
- State-
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified NetBIOS name registration state. The following are possible values for this parameter:
must_register
must_unregister
wins
broadcast
name_released
wins_conflict
broadcast_conflict
[-time-left <integer>]
- Time Left-
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified registration time left in minutes with the WINS server.
[-type <text>]
- Type-
If you specify this optional parameter, the command displays the NetBIOS name service information only for the specified name registration type. The following are possible values for this parameter:
registered
active
permanent
group
The following example displays the NetBIOS name service information.
cluster1::> nbtstat (vserver cifs nbtstat) Vserver: vs1 Node: cluster1-01 Interfaces: 10.10.10.32 10.10.10.33 Servers: 17.17.1.2 (active ) NBT Scope: [ ] NBT Mode: [h] NBT Name NetBIOS Suffix State Time Left Type ------------------ --------------- ------------- --------- ----- CLUSTER_1 00 wins 57 CLUSTER_1 20 wins 57 Vserver: vs1 Node: cluster1-02 Interfaces: 10.10.10.35 Servers: 17.17.1.2 (active ) CLUSTER_1 00 wins 58 CLUSTER_1 20 wins 58 4 entries were displayed.
