ONTAP commands
statistics port fcp show
FCP port interface throughput and latency metrics
This command continuously displays performance data for FCP ports at a regular interval. The command output displays data in the following columns:
  • Port - port name.
  • Read Ops - read operations per second.
  • Write Ops - write operations per second.
  • Other Ops - other operations per second.
[-port <text>] - Port
Selects the port for which you want to display performance data.
[-sort-key <text>] - Column to Sort By
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer> - Interval
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer> - Iterations
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer> - Maximum Number of Instances
Specifies the maximum number of ports to display. The default setting is 25.
The following example displays port statistics:
cluster1::> statistics port fcp  show
cluster1 : 12/31/2013 16:00:04
       *Total Read Write
 Port     Ops  Ops   Ops
 port1      2    2     0
 port2      3    0     3
