system controller flash-cache secure-erase show
Display the Flash Cache card status
The system controller flash-cache secure-erase show
command displays the current Flash Cache device secure-erase status.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
If this parameter is specified, only status information for the matching node is displayed.
[-slot <text>]
- Slot-
If this parameter is specified, only status information for the matching slot is displayed. Slot can have a format of slot or slot-subslot.
[-device-state {ok|erasing|erased|failed|removed}]
- Device State-
If this parameter is specified, only status information for the matching device-state is displayed.
The following example displays the current state of all the Flash Cache devices:
cluster1::> system controller flash-cache secure-erase show Node Slot Device State --------- ---- ------------ node1 6-1 ok 6-2 erasing node2 6-1 erased 6-2 ok 4 entries were displayed.
