The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system node power on
PDF of this doc site
Creating your file...
Your file is ready
Power nodes on
This command switches on the power of the main controller of the specified node. This command works for a single node only and the full name of the node must be entered exactly.
-node {<nodename>|local}
- Node (privilege: advanced)-
This parameter specifies the node whose power you want to switch on.
The following example switches on the power of node2.
cluster1::> set advanced Warning: These advanced commands are potentially dangerous; use them only when directed to do so by NetApp personnel. Do you want to continue? {y|n}: y cluster1::*> cluster1::*> system node power on -node node2 cluster1::*>
