The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver fpolicy policy event delete
PDF of this doc site
Creating your file...
Your file is ready
Delete an event
The vserver fpolicy policy event delete
command deletes an FPolicy event.
-vserver <Vserver Name>
- Vserver-
This parameter specifies the Vserver from which you want to delete an FPolicy event.
-event-name <Event name>
- Event-
This parameter specifies the name of the FPolicy event you want to delete.
The following example deletes an FPolicy event.
cluster1::> vserver fpolicy policy event delete -vserver vs1.example.com -event-name cifs_event
