cluster log-forwarding show
Display log forwarding destinations
The cluster log-forwarding show
command displays log forwarding information:
Destination (IPv4/IPv6/hostname)
Port number
List of log classes
Facility
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-destination <Remote InetAddress>]
- Destination Host-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified host name, IPv4 or IPv6 address.
[-port <integer>]
- Destination Port-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified ports.
[-protocol {udp-unencrypted|tcp-unencrypted|tcp-encrypted}]
- Log Forwarding Protocol-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified protocols.
[-verify-server {true|false}]
- Verify Destination Server Identity-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified verify-server values.
[-facility <Syslog Facility>]
- Syslog Facility-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified facility.
cluster-1::> cluster log-forwarding show Verify Syslog Destination Host Port Protocol Server Facility ------------------------ ------ --------------- ------ -------- 192.168.0.1 514 udp-unencrypted false user
