vserver vscan on-demand-task report delete
Delete an On-Demand report
The vserver vscan on-demand-task report delete command deletes an On-Demand report.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver from which you want to delete an On-Demand report.
-task-name <text> - Task Name
This parameter specifies the name of the On-Demand task whose report you want to delete.
-report-file <text> - Report File Path
This parameter specifies the path of the report-file whose report record you want to delete.
[-delete-report-file {true|false}] - Delete Report File Also
This parameter specifies if the corresponding report file is also to be deleted. By default, it is false.
The following example deletes only On-Demand report record:
cluster1::> vserver vscan on-demand-task report delete -vserver vs1 -task-name t1
            -report-file /rep/avod_146_20150902_161439.log
There are no entries matching your query.
The following example deletes an On-Demand report file along with the report record:
            -report-file /rep/avod_146_20150902_161439.log -delete-report-file true
