The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver services ndmp on
PDF of this doc site
Creating your file...
Your file is ready
Enable NDMP service
This command is used to enable NDMP service on a specific Vserver.
-vserver <Vserver Name>
- Vserver-
This parameter specifies the name of the Vserver.
The following example enables NDMP service on a specific Vserver:
cluster1::> vserver services ndmp on -vserver vs1
