snapmirror object-store profiler show
The snapmirror object-store profiler show
command is used to monitor progress and results of the snapmirror object-store profiler start command.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node <nodename>]
- Node Name-
This parameter specifies the node on which the profiler was started.
[-object-store-name <text>]
- ONTAP Name for this Object Store Configuration-
This parameter specifies the object store configuration that describes the object store. The object store configuration has information about the object store server name, port, access credentials, and provider type.
[-profiler-status <text>]
- Profiler Status-
Current status of the profiler.
[-start-time <MM/DD/YYYY HH:MM:SS>]
- Profiler Start Time-
Time at which profiler run started.
[-op-name <text>]
- Operation Name - PUT/GET-
Name of the operation. Possible values are PUT or GET.
[-op-size {<integer>[KB|MB|GB|TB|PB]}]
- Size of Operation-
Size of the PUT or GET operation.
[-op-count <integer>]
- Number of Operations Performed-
Number of operations issued to the object store.
[-op-failed <integer>]
- Number of Operations Failed-
Number of operations that failed.
[-op-latency-minimum <integer>]
- Minimum Latency for Operation in Milliseconds-
Minimum latency of the operation in milliseconds, as measured from the filesystem layer.
[-op-latency-maximum <integer>]
- Maximum Latency for Operation in Milliseconds-
Maximum latency of the operation in milliseconds, as measured from the filesystem layer.
[-op-latency-average <integer>]
- Average Latency for Operation in Milliseconds-
Average latency of the operation in milliseconds, as measured from the filesystem layer.
[-op-throughput {<integer>[KB|MB|GB|TB|PB]}]
- Throughput per Second for the operation-
Throughput per second for the operation.
[-op-errors <text>,…]
- Error Reasons and Count-
Error reasons and count for failed operation.
[-op-latency-histogram <text>,…]
- Latency Histogram-
Latency histogram for the operation.
The following example displays the results of snapmirror object-store profiler start :
cluster1::>snapmirror object-store profiler show
