The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver nfs delete
PDF of this doc site
Creating your file...
Your file is ready
Delete the NFS configuration of a Vserver
The vserver nfs delete
command deletes the NFS configuration of a specified Vserver. This command does not delete the Vserver itself, just its ability to serve NFS clients.
If you delete a Vserver, the Vserver's NFS configuration is automatically deleted. Any Windows-to-UNIX or UNIX-to-Windows name mappings defined for the Vserver are also deleted because they require both the CIFS and NFS servers. |
-vserver <vserver name>
- Vserver-
This specifies the Vserver whose NFS configuration you want to delete.
The following example deletes the NFS configuration of a Vserver named vs2:
cluster1::> vserver nfs delete -vserver vs2
