The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network tuning icmp6 modify
PDF of this doc site
Creating your file...
Your file is ready
Modify ICMPv6 tuning options
This command displays options which can be used to fine tune icmpv6 protocol behavior.
-node {<nodename>|local}
- Node-
Sets this parameter to indicate on which node the ICMPv6 tuning options are modified.
[-is-v6-redirect-accepted {true|false}]
- Accept redirects via ICMPv6-
Sets this parameter to indicate whether or not redirect ICMPv6 messages are accepted.
[-redirect-v6-timeout <integer>]
- Maximum seconds for route redirect timeout-
Sets this parameter to indicate the number of seconds after which the route is deleted. Value of zero means infinity. The default value is 300 seconds.
cluster1::> network tuning icmp6 modify -node node1 -is-v6-redirect-accepted false
